TYAMA.2
Sep 19, 2025 3:46 AM UTC
Add Custom Service
I want to add a custom BLE service in STM32CubeMX. I saw on a website that the Add Custom Service feature could be used for this. However, I don't know the procedure for adding a service using this feature. Please tell me the steps to add a service using the Add Custom Service feature in the latest IDE and MX environment.
STTwo-32
STTwo-32Best answer
Sep 19, 2025 4:27 PM UTC
Hello @TYAMA.2
On the BLE Applications and Services tab, you have to select the number of services you want to implement. Once this is done, N new tab will be added to your configuration view (N is the number of services you selected):
On each of the new tab you can configure the service you are looking for:
Best Regards.
STTwo-32
TYAMA.2
TYAMA.2Author
Sep 19, 2025 4:26 AM UTC
Thanks for your reply.
Is "Number of services" where I add new services? (Please see the attachment.)
Is there an item called "Add Custom Service"?
If possible, please show me with a screenshot.
STTwo-32
STTwo-32Best answer
Hello @TYAMA.2
Best Regards.
STTwo-32
TYAMA.2
TYAMA.2Author
Sep 22, 2025 4:07 AM UTC
Thank you for your reply.
I understand that the normal way to add services is "Number of services".
Thank you.
STTwo-32
Sep 22, 2025 5:28 AM UTC
Since your question is answered. Please accept the comment that answer your question as solution to close this post.
Best Regards.
STTwo-32
