digidhamu
Apr 8, 2022 1:06 PM UTC
120mA current consumption when supply external 3V3 power - Nucleo-WL55JC1 (CN6)
When you power Nucleo-WL55JC! with external 3V3 via CN6, I could see constant 120mA current consumption. Is there any way we can reduce this?
digidhamu
digidhamuAuthor
Apr 8, 2022 1:24 PM UTC
I have tried removing 5V_PWR jumper JP7 and no jumpers on JP4 as per the documentation but no luck
Louis AUDOLY
Apr 19, 2022 3:44 PM UTC
Can you tell me which program you are using to reproduce your behavior please.
Have a nice day
digidhamu
digidhamuAuthor
Apr 19, 2022 4:04 PM UTC
LoRaWAN_End_Node application provided by ST under this path
Projects/NUCLEO-WL55JC/Applications/LoRaWAN/LoRaWAN_End_Node
Thanks LAUDO and wait for your advise.
digidhamu
digidhamuAuthor
May 9, 2022 2:48 AM UTC
Is there any update on this @Louis AUDOLY​ as I waiting to solve of my use cases
Louis AUDOLY
May 9, 2022 4:35 PM UTC
Hello @digidhamu​ ,
Sorry for the late reply
I tested the power consumption of a nucleo board with the end_node project and my consumption were around 20mA when we did a Tx and a below 200uA when nothing happen.
Don't you have any expansion board connected to the nucleo ?
Best regards
digidhamu
digidhamuAuthor
May 13, 2022 1:52 AM UTC
Thanks @Louis AUDOLY​ I didn't connect any expansion board. Would it possible to send picture of your setup and this will help me to report you back faster?
