Jzhan.81
我在使用STM32CUBEMX生�?GUI代�?完�?�?�,在工程目录TouchGFX里�?�打开Applacation Template.touchgfx.part文件�?�,desigener报错,Error: 无法对 null 引用执行�?行时绑定,请问下这个问题怎么解决
  • June 23, 2021
  • 7 replies
  • 4407 views
Alexandre RENOUX
June 23, 2021
Hello Jzhan.8,
Could you tell us in English the steps you did to arrive to this unexpected error ? Can you reproduce it ?
/Alexandre
Jzhan.81
Jzhan.81Author
OK,After using stm32cubemx to generate GUI code, I open the application template.touchgfx.part file in the project directory TouchGFX, and the designer reports an error. Error: I can't perform runtime binding on null reference. How can I solve this problem?Thanks~
Jzhan.81
Jzhan.81Author
Yes,I can reproduce it,it always does that,I haven't sloved it yet.
Jzhan.81
Jzhan.81Author
When I used STM32CUBEMX to generate GUI code,it's not appearing any warning and wrong.
Alexandre RENOUX
June 23, 2021
Hi Jzhan.8,
Could you enclose your .touchgfx.part (and .touchgfx files if you have it) ?
/Alexandre
Jzhan.81
Jzhan.81Author
Can I add your Wechat or QQ?I can send it to you through it.
Alexandre RENOUX
June 23, 2021
Unfortunately I don't have WeChat nor QQ.
You can send it to me by private message on this community.
/Alexandre
Jzhan.81
Jzhan.81Author
I haved sent it to you through privacy communication.
Alexandre RENOUX
June 23, 2021
Your touchgfx.part is empty. It should not happen.
Can you tell me exactly the steps you did to generate it ?
Did you use CubeMX, add the TouchGFX Generator additional software to your project and generate code ?
/Alexandre
Jzhan.81
Jzhan.81Author
Yes,I use cubemx,here are my steps;
0693W00000Bbl5fQAB.png0693W00000Bbl5uQAB.png0693W00000Bbl6EQAR.png0693W00000Bbl6YQAR.png
