What is your question exactly ? Does the Nucleo-G070RB supports the X-Nucleo-GFX01K1 display ? If yes, then it does. Since you added the TouchGFX tag I suppose you are wondering if it will work with TouCHGFX ? The answer is also yes, but there are no application templates available in TouchGFX Designer. You can have a look at the application template for the STM32G071-nucleo board, which uses the X-Nucleo-GFX01K1 display, and use it to configure your project.
/Romain
