BParh.1
Senior III
June 17, 2021
Why negative values shown on X axis of dynamic graph when just switched form invisible to visible?
Step to reproduce the issue:
  1. Setup a dynamic graph widget with X axis label
  2. Setup a button to switch the graph invisible and visible i.e. :
buttonHandler() {
 if(graph.isVisible()) {
 graph.setVisible(false);
 graph.invalidate();
 else {
 graph.setVisible(true);
 graph.invalidate();
Run the application, wait until the graph roll at least one screen length. Then click the button 2x to make it invisible and visible again. The X axis label become negative at point where we left the graph.
Why so? and how can I avoid this?
Alexandre RENOUX
June 21, 2021
Hello BParh.1,
I cannot reproduce your issue.
Could you tell me more about your project and/or include the use case project here ?
/Alexandre
BParh.1
BParh.1Author
Senior III
June 21, 2021
Hi @Alexandre RENOUX​ , thank you for your attention.
I'd cannot include directly my project file, but I'd find time to create a strip down version and get back to you.
BParh.1
BParh.1Author
Senior III
July 2, 2021
Hi @Alexandre RENOUX​  sorry for the late replay, I have been busy. I don't have time yet to create this strip down project and I cannot share my project code for intellectual property issue.
But here I attach how some of the x label area negative. Those area are one yet to overwrite (in wrap and overwrite mode). As a start, is there any work around I can do to resolve this?
