JChi
Which ST MCU can support LCD with resolution HD and Full HD@60hz ?
  • August 21, 2019
  • 1916 views
Hi all!
I want to find a MCU of ST can support LCD with resolution HD and Full HD@60hz (MIPI or RGB Interface). Please suggest me some series that I can use.
Thank you so much!
There is a large selection of STM32 microcontrollers which may answer your request.
I recommend you to use the "ST-MCU-FINDER" tool (mobile version, PC version or the one embedded in STM32CubeProgrammer and STM32CubeMX) to fine tune your choice and the select the suitable MCU.
Video: How to use our ST MCU Finder
Best Regards,
Imen
waclawek.jan
Probably none.
Review AN4861. While it does not contain the 'H7, the basic constraints are similar.
August 21, 2019
Two channel DSI pretty limiting, and SDRAM bandwidth.​
