sini
May 26, 2023 5:35 AM UTC
Whether the server logs when TouchGFX Designer downloads board setup and example
I understand that when TouchGFX Designer starts, it connects to the server and downloads board setup and example.
I want to know that server logs or not because my company security policy.
Thank you and regards
Yoann KLEIN
Yoann KLEINBest answer
Jun 13, 2023 1:00 PM UTC
Hello @sini​,
The logs of TouchGFX Designer are contained inside C:\Users\username\AppData\Roaming\TouchGFX-4.21.4\TouchGFXDesigner.log.
There you will be able to see most things that happen during TouchGFX Designer startup, connection to servers and basically almost all that happens when you use the tool.
/Yoann
Yoann KLEINST Software Developer | TouchGFX
Yoann KLEIN
Hello @sini​,
/Yoann
