CGong.1
Feb 22, 2020 10:08 AM UTC
Where is the "Configuring-STM32F746G-DISCO" page?
Where is the "Configuring-STM32F746G-DISCO" page? I used to see this topic in the help center, but now I can't find it. The previous URL was "https://touchgfx.zendesk.com/hc/en-us/articles/360019884752-Configuring-STM32F746G-DISCO". Now this link can't be opened, and I can't search for this topic, Where does this topic go? Was it deleted? Is there an alternative theme?
Romain DIELEMAN
Feb 24, 2020 8:32 AM UTC
this article has been removed because it was outdated. What is your ambition with it? If you just wish to run a project on your board, you can start from the application template in Designer when you create a new project. Everything will then be configured automatically and you can have a look at the generated CubeMX project. If you wish to learn how to port a board yourself the article has a lot of outdated content since it was meant for an older version of CubeMX.
\Romain
CGong.1
CGong.1Author
Feb 25, 2020 12:53 PM UTC
Hello Romain, Thanks for your reply! For some reason, I had to use an older version of STM32CubeMX, which is earlier than 5.4.0. Previously, I referred to the "Configuring-STM32F746G-DISCO" page and established the STM746G-DISCO project, and modified this project according to the instructions on this page to make it work normally. But now I can't find this page, it's very bad, I forgot some steps in this page. May I ask if you have a backup of this file, can you send me a copy, thank you. Chen �?��?自 Windows 10 版邮件<>应用
Romain DIELEMAN
Feb 25, 2020 1:33 PM UTC
Hi, ok then I will try to find a backup for it and link it here
Martin KJELDSEN
Principal III
Feb 25, 2020 2:35 PM UTC
CGong.1
CGong.1Author
Mar 6, 2020 2:05 AM UTC
Yes, this is the document I need. Thank you very much. That's great!
