JaHnu
Mar 25, 2019 6:35 AM UTC
Where is BMPFileLoader?
I didn't find “dynamic_bitmap_example“ in TouchGFX
Martin KJELDSEN
Martin KJELDSENBest answer
Principal III
Mar 28, 2019 10:25 PM UTC
Hi @JaHnu​
A Dynamic Bitmap in TouchGFX is not necessarily just loading a BMP, dynamically. It means that you can modify a piece of memory at runtime and treat it as a Bitmap in TouchGFX. But, now that we're on the subject, you're right that the dynamic_bitmap_example from TouchGFX 4.8.0 has not made its way into the designer yet.
I've attached it here (based on 4.8.0).
/Martin
Martin KJELDSEN
Principal III
Hi @JaHnu​
/Martin
JaHnu
JaHnuAuthor
Mar 29, 2019 1:43 AM UTC
Thank you Martin KJELDSEN
Martin KJELDSEN
Principal III
Mar 29, 2019 7:27 AM UTC
You're welcome!
Iswarya
Apr 4, 2019 5:57 PM UTC
Missing lot of files.
Martin KJELDSEN
Principal III
Apr 8, 2019 7:38 AM UTC
This example is not maintained - I grabbed it from an old release. It should definitely be made into a UI template.
