vtunr
Oct 21, 2019 4:44 PM UTC
Weird behavior when animation
I'm working with TouchGFX with STM32F746BG, and I have an issue when there is animation.
You can find a video of the problem here : https://youtu.be/X-D-NkGCN5k
I also have the same issue when I add an animation between screen.
At the beginning I was working without TouchGFX (and without external ram), playing with LTDC layer, moving and everything and I no issue.
Any idea where this could come from ?
Tony
EDIT: Updated video to the right one
vtunr
vtunrBest answer
Dec 5, 2019 3:35 PM UTC
Switched to 16bits, working fine now.
Also some improvements come from :
  • Putting framebuffer in different memory bank
  • For 24 bit, setting 832 pixel wide
They are explained : https://www.st.com/content/ccc/resource/technical/document/application_note/group0/25/ca/f9/b4/ae/fc/4e/1e/DM00287603/files/DM00287603.pdf/jcr:content/translations/en.DM00287603.pdf (4.5.2, 4.5.3)
Martin KJELDSEN
Principal III
Oct 22, 2019 9:38 AM UTC
I'm getting a video that shows you trying to drag a slider. Is that the right video? I can't tell anything is wrong other than there is no touch registered. Does touch work generally for your board?
/Martin
vtunr
vtunrAuthor
Oct 22, 2019 9:57 AM UTC
Sorry, yesterday I posted the wrong video, updated it this morning, but kept the thumbnail from yesterday, here's the link again : https://youtu.be/X-D-NkGCN5k
vtunr
vtunrAuthorBest answer
