Tuoman
Senior II
August 27, 2020
Using superscript or subscript in TouchGFX?
  • August 27, 2020
  • 3 replies
  • 1109 views
Is there any easy way to use superscript or subscript in TouchGFX, or need to do custom implementation for it?
I need subscripts in particular, which can appear in arbitrary numbers in middle of text fields.
Maybe I can convert unicode characters to their subscript equivalent character, between 0x2000-0x2084 range.
I will post solution here if I figure this out.
Best answer by Martin KJELDSEN
Sure, that's true. I was answering your question "Is there any easy way to use superscript or subscript in TouchGFX?". Indicating that TouchGFX simply uses Unicodes implies that you need your font to support those sub/super-scripts. Either by manual labor or otherwise.
We sometimes use FontForge here to manipulate fonts. You can even use the reserved areas of a font for whatever you want.
/Martin
Martin KJELDSEN
Principal III
August 28, 2020
Super- and subscripts have dedicated unicodes, so they'll be in your font. It's no different than typing "ABC".
Tuoman
TuomanAuthor
Senior II
August 31, 2020
Unfortunately the Unicode table is missing many subscript characters...
https://en.wikipedia.org/wiki/Unicode_subscripts_and_superscripts
How would one write subscript b or c for example?
Martin KJELDSEN
Martin KJELDSENBest answer
Principal III
August 31, 2020
/Martin
