JKim.51
Nov 7, 2022 10:50 PM UTC
Using STM32H735, Can I play any video clip?
TouchGFX has video clip play example for STM32H735-DK EVB.
But It is not working.
Osman SOYKURT
Osman SOYKURTBest answer
Nov 10, 2022 9:51 AM UTC
Hello JKim.51,
I confirm for this board, the video decoding is not supported. Indeed, it requires JPEG codec and this board has not. We have an article talking more about video decoding, I invite you to have a look on it if you're interested.
/Osman
Nov 7, 2022 10:58 PM UTC
Probably not
Video comes in many formats, you'd need a suitable decoder for each format you want to use, or transcode on the PC into a supported format. Most are encumbered with IP and licensing costs, and may not be efficient without hardware assistance.
Likely only MJPEG
JKim.51
JKim.51Author
Nov 7, 2022 11:10 PM UTC
In case of MJPEG, Can STM32H735 play the MJPEG video clip?
Nov 7, 2022 11:33 PM UTC
Not sure, I don't see reference to the JPEG CODEC that's on other H7's including the H7B3
The MCU can't do much without appropriate software.
JKim.51
JKim.51Author
Nov 7, 2022 11:41 PM UTC
Thank you for answer. :)
Osman SOYKURT
Hello JKim.51,
/Osman
AScha.3
Nov 10, 2022 10:10 AM UTC
well, you can play video, if your TFT has any controller, which is supporting video/decoding , so the cpu has not so much (or too much :) ) to do;
i have here 7" TFT, 800x480 pix, with EVE controller and SPI connected to stm32H7A3 board;
read about displays with such controller, so you can play video ;
http://brtchip.com/eve/
displays with EVE :
https://riverdi.com/product-category/intelligent-displays/bt817q/?pr=22829
https://www.matrixorbital.com/eve3-70a
and the library i use is by Rudoph :
https://github.com/RudolphRiedel
https://www.mikrocontroller.net/topic/395608
Nov 10, 2022 1:16 PM UTC
In it simplest form video can just be the dumping of frames into the frame buffer. The volume of data can become quite high​, and then you use compression methods as a means of balancing data volume vs processing bandwidth.
