Sandor Bedo
Jun 4, 2018 8:39 AM UTC
Using 2 device with FSMC?
Posted on June 04, 2018 at 10:39
Right now I am facing with the next issue:
I am using FSMC to drive an SDRAM (IS66WV51216) and an LCD (
https://shop.boxtec.ch/tft-lcd-shield-for-arduino-unomega-ili9481-p-42762.html?language=en
). As I use only the SDRAM without TFT, the write and read works fine, but as I connect the display the write/read operations have interesting issues.
As I write 1k data in to the SDRAM from 0-1023 and as I read back the numbers are strange (0 0 1 1 7 7 7 7 23 23 ...).
But  as I use only the TFT with FSMC it also works fine.
I use the next settings:
  • NE1, NE2 -> PULL UP
  • DATA [0 - 16] -> PULL DOWN
  • ADDRES[0 - 18] -> NO RESISTOR
  • NWE -> PULL UP
  • NOE -> PULL UP
  • A25 -> this is connected to RS pin of TFT (data or command selector) NO RESISTOR
The data pins from 0-8 bits are common as the NWE and the NOE pins.
The data widths of the devices:
  • TFT => 8 bits
  • SDRAM => 16 bits
So separately both device work, but as I would like to use them in one SW it does not work.
I am using STM32F417ZET6 uC.
Have anybody any idea what should I set up to solve this problem?
#tft-and-sdram #sdram-fsmc #fsmc
Sandor Bedo
Jun 4, 2018 9:09 AM UTC
Posted on June 04, 2018 at 11:09
I forgot to attach the configs:
/*  TFT configuration */
hsram1
Instance
FSMC_NORSRAM_DEVICE
hsram1
Extended
FSMC_NORSRAM_EXTENDED_DEVICE
/* hsram1.Init */
hsram1
Init
NSBank
FSMC_NORSRAM_BANK1
hsram1
Init
DataAddressMux
FSMC_DATA_ADDRESS_MUX_DISABLE
hsram1
Init
MemoryType
FSMC_MEMORY_TYPE_SRAM
hsram1
Init
MemoryDataWidth
FSMC_NORSRAM_MEM_BUS_WIDTH_8
hsram1
Init
BurstAccessMode
FSMC_BURST_ACCESS_MODE_DISABLE
hsram1
Init
WaitSignalPolarity
FSMC_WAIT_SIGNAL_POLARITY_LOW
hsram1
Init
WrapMode
FSMC_WRAP_MODE_DISABLE
hsram1
Init
WaitSignalActive
FSMC_WAIT_TIMING_BEFORE_WS
hsram1
Init
WriteOperation
FSMC_WRITE_OPERATION_ENABLE
hsram1
Init
WaitSignal
FSMC_WAIT_SIGNAL_DISABLE
hsram1
Init
ExtendedMode
FSMC_EXTENDED_MODE_DISABLE
hsram1
Init
AsynchronousWait
FSMC_ASYNCHRONOUS_WAIT_DISABLE
hsram1
Init
WriteBurst
FSMC_WRITE_BURST_DISABLE
hsram1
Init
PageSize
FSMC_PAGE_SIZE_NONE
/* Timing */
Timing
AddressSetupTime
2
Timing
AddressHoldTime
1
Timing
DataSetupTime
16
Timing
BusTurnAroundDuration
15
Timing
CLKDivision
16
Timing
DataLatency
17
Timing
AccessMode
FSMC_ACCESS_MODE_A
/* SDRAM configuration */
hsram2
Instance
FSMC_NORSRAM_DEVICE
hsram2
Extended
/* hsram2.Init */
hsram2
Init
NSBank
FSMC_NORSRAM_BANK2
hsram2
Init
DataAddressMux
hsram2
Init
MemoryType
hsram2
Init
MemoryDataWidth
FSMC_NORSRAM_MEM_BUS_WIDTH_16
hsram2
Init
BurstAccessMode
hsram2
Init
WaitSignalPolarity
hsram2
Init
WrapMode
hsram2
Init
WaitSignalActive
hsram2
Init
WriteOperation
hsram2
Init
WaitSignal
hsram2
Init
ExtendedMode
hsram2
Init
AsynchronousWait
//FSMC_ASYNCHRONOUS_WAIT_ENABLE;
hsram2
Init
WriteBurst
hsram2
Init
PageSize
FSMC_PAGE_SIZE_NONE
/* Timing */
Timing
AddressSetupTime
15
Timing
AddressHoldTime
10
/* 1 */
Timing
DataSetupTime
200
/* 16 */
Timing
15
Timing
CLKDivision
16
Timing
DataLatency
17
Timing
AccessMode
FSMC_ACCESS_MODE_A
