Jan 3, 2024 4:30 PM UTC
Use ITCM for dynamic Bitmap (TouchGFX 4.18)
Hello, I'm using an STM32H750 and I need to implement a single small dynamic bitmap, but I have only ITCM RAM available. I read and made all the code from the article
https://support.touchgfx.com/docs/development/ui-development/touchgfx-engine-features/dynamic-bitmaps
but the funcion Bitmap::dynamicBitmapCreate return INVALID.
The question is: is it possible to use ITCM for this purpose? I'm using IAR 8.32
Thank you
MarcoSilenziBest answer
Jan 8, 2024 1:10 PM UTC
I forgot to have SRAM 1-2-3 available and they works perfectly for my purpose.
Thank you
Jan 8, 2024 7:23 AM UTC
Solved, please close the post
Lina_DABASINSKAITE
ST Community Manager
Jan 8, 2024 12:24 PM UTC
Hello @MarcoSilenzi ,
Can you share the solution? After that I am happy to close the post.
Regards,
Lina
​In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
MarcoSilenziAuthorBest answer
Thank you
