JKim.1006
Nov 8, 2019 5:47 AM UTC
Tutorial 1 Run target error
I bought a stm32H747I DISCO for using TouchGFX.
Now I'm following steps of tutorial 1, but Run target is not working.
I will attach Detatiled Log.
Thank you.
Run Target
  Generate
    Done
  Generate Assets
    make -f simulator/gcc/Makefile assets -j8
    Converting images
    Done
  Post Generate
    touchgfx update_project --project-file=simulator/msvs/Application.vcxproj && touchgfx update_project --project-file=../EWARM/TouchGFX.ewp
    Done
  Compile
    make -f ../gcc/Makefile -j8
    STM32CubeProgrammer is placed in Program Files
    Converting images
    Linking TouchGFX/build/bin/target.elf
    Producing additional output formats...
     target.hex  - Combined internal+external hex
     intflash.elf - Internal flash, elf debug
     intflash.hex - Internal flash, hex
     extflash.bin - External flash, binary
    Done
  Flash
    make -f ../gcc/Makefile -j8 flash
    Converting images
    /usr/bin/sh: C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer\bin\STM32_Programmer_CLI.exe: No such file or directory
    gcc/Makefile:334: recipe for target '_extflash_' failed
    make[1]: *** [_extflash_] Error 127
    make: *** [flash] Error 2
    ../gcc/Makefile:50: recipe for target 'flash' failed
    Failed
  Failed
Martin KJELDSEN
Martin KJELDSENBest answer
Principal III
Nov 8, 2019 1:44 PM UTC
You need to install STM32CubeProgrammer.
/Martin
Martin KJELDSEN
Principal III
/Martin
DMeis.1
Jan 21, 2020 9:23 PM UTC
Run Target
 Generate
 Done
 Generate Assets
 make -f simulator/gcc/Makefile assets -j10
 Converting images
 Done
 Post Generate
 touchgfx update_project --project-file=../EWARM/STM32F7508_DISCO.ewp --gui-group-name=Application/User/TouchGFX/gui --generated-group-name=Application/User/TouchGFX/generated && touchgfx update_project --project-file=simulator/msvs/Application.vcxproj
 Done
 Compile
 Converting images
 Done
 Flash
 Converting images
 /usr/bin/sh: C:\Program Files (x86)\STMicroelectronics\STM32 ST-LINK Utility\ST-LINK Utility\ST-LINK_CLI.exe: No such file or directory
 gcc/Makefile:311: recipe for target '_flash_' failed
 make[1]: *** [_flash_] Error 127
 Failed
 Failed
I am getting a similar error, i don't know how to install STM32 ST-Link
DMeis.1
Jan 21, 2020 9:29 PM UTC
