May 15, 2025 1:56 PM UTC
TouchGFXEnvPath and version control system
Our project with TouchGFX uses a version control system (git, of course). In your documentation, you recommend the `config`directory to be included in the VCS. The pain point is that `TouchGFXEnvPath` tag in `config\msvs\Application.props` contains the 'TouchGFX Designer' installation path and might change from a developer to another. I don't know if `config\gcc` should be versioned, but I think that `config\msvs` should not. Am I missing something ?
Thank you
    GaetanGodart
    GaetanGodartBest answer
    Jun 3, 2025 1:13 PM UTC
    Hello @Jonadem ,
    I think we have changed our point of view on the config folder because we do ignore it in our VCS internally.
    I think you can just ignore that folder for your VCS.
    Regards,
    Gaetan GodartSoftware engineer at ST (TouchGFX)
    GaetanGodart
    Hello @Jonadem ,
    Regards,
