Jul 30, 2025 8:40 AM UTC
touchgfx4.25.0 show color wrong
It should be purple, but it shows up as blue. background is svg picture is normal.
youxueAuthor
Sep 30, 2025 3:00 AM UTC
I'm sure the issue lies in the code generated by TouchGFX or STM32CubeMX, because the problem persists even after I replaced it with a new screen. However, projects developed with other tools have normal screen colors.
Osman SOYKURT
Oct 9, 2025 9:14 AM UTC
Hello @youxue
Are you sure you're using the same color format with the other tool?
I can see from your ioc file that you're using an LTDC display. So I would suggest you to follow the procedure described in this article to show just 1 solid color on your screen , without using TouchGFX. This way we could say or not if the issue is coming from TouchGFX or CubeMX as you claim.
