Martin KJELDSEN
Martin KJELDSENBest answer
Principal III
May 20, 2019
Hi @CStie​ ,
Yes, this is definitely possible. It is not integrated into CubeMX yet, so for any MCU it would require TFT / DSI Controller as of now.
If you do not have a signal from your display, you can use a hardware timer, yes, to generate the VSYNC.
/Martin
Khouloud ZEMMELI
​Hello @CStie​
This's reported internally for further check.
Best Regards,
Khouloud.
Martin KJELDSEN
Principal III
May 20, 2019
Hi @CStie​ ,
/Martin
scottSD
Senior III
April 13, 2020
@Martin KJELDSEN​ Just curious if this has been given any further investigation?
For a few of our applications, we are planning on using TFTs with on-board controllers which do not use standard 24 bit RGB (or RGB565) so we will not be using the LTDC.
We were planning on writing our own driver for it but was wondering if the "Custom" display interface for the TouchGFX has been looked at by ST?
Martin KJELDSEN
Principal III
April 14, 2020
Hi @scottSD​,
It depends on what you mean by "further investigation" - At some point it's just not possible to get any further since the display is a custom component and we can't know how to send data to it.
/Martin
scottSD
Senior III
April 14, 2020
@Martin KJELDSEN​  I understand your point as of course not every possible display could be accommodated.
On this topic, do you know where the following article ended up on the new documentation?
https://touchgfx.zendesk.com/hc/en-us/articles/203642951-MCUs-without-TFT-controller
We are currently attempting this and running into some issues. This article has recently been removed from zendesk and we were referring to it in our development.
