Mar 18, 2026 6:27 AM UTC
TouchGFX v4.26.1 doesn't copy touchgfx_core.a to project folder?
Is this version do not copy touchgfx_core.a to project folder? ex) Middlewares\ST\touchgfx\lib\core\cortex_m4f\IAR8.x
because I did generate code in touchGFX so automatelly remove the files in lib/core.
and i can't build on IAR because .ipcf file generated from touchGFX desinger need touchgfx_core.a of path above.
    Mar 18, 2026 10:42 AM UTC
    Hello @daniel9.Which toolchain have you selected in STM32CubeMX?
    Is the lib/core folder completely empty, or does it contain the library for a different compiler?
    Can you share your project?
    Best regards,
    Johan
    Jul 3, 2026 10:44 AM UTC
    Hello again.
    Just checking in to hear whether you were able to resolve your issue .. ?
    Best regards,
    Johan
