May 23, 2026 7:50 AM UTC
TouchGFX touch coordinate mismatch on STM32H7B3 hardware
Hello ST Community,
I am using STM32H7B3 + TouchGFX + 7-inch 800×480 TFT with GT911/GT9111 touch controller.
In the TouchGFX PC simulator, all buttons and toggle switches work correctly. But after flashing to hardware:
  • TFT display is working properly.
  • Touch is detected.
  • Actual touch point and detected touch point are different.
  • Touch is detected on the same horizontal line, but the vertical coordinate is shifted/wrong.
I want to know the correct solution for touch coordinate mapping/calibration. Should this correction be done.
Please guide me on the correct method for touch calibration and hardware control/status display in TouchGFX.
Thank you.
Osman SOYKURT
Jul 2, 2026 10:08 AM UTC
Hello ​@vijayajangam ,
Which version of TouchGFX do you use? Which version of the firmware do you use (STM32Cube_FW_H7_VX.XX.X)?
Could you share what you do in your sampleTouch() function?
