Romain DIELEMAN
Romain DIELEMANBest answer
May 18, 2023 12:53 AM UTC
TouchGFX works with any Parallel RGB (LTDC), MIPI DSI, FMC or SPI displays. So yes your display will work.
/Romain
Romain DIELEMAN
/Romain
non
nonAuthor
May 18, 2023 1:36 AM UTC
Do you have a sample link? Because I only have the library I found from the website I attached. The examples I found only ST7735 ILI8488 did not find ST7736.
cchar.2
May 23, 2023 1:56 PM UTC
ili9488 and ili7796 are very similar, the only difference between the two is the initial code,You can refer to the appropriate routines in www.lcdwiki.com website
