CPrad.1
TouchGFX simulator read an external csv file.
I need to create a graph in TouchGFX where the points on that graph will be read from a .csv file. In that first moment I will use only the TouchGFX simulator. Would you have an example where the simulator can read data from a csv file and create the graph?
MM..1
I mean you can use FrontendApplication.cpp file for this load .
