Kasun Dinesh
Jul 25, 2020 7:51 PM UTC
Touchgfx Simulation does not run after project pulled from git
I am getting a issue with simulating touchgfx projects. These are the steps I followed.
  1. Create a working touchgfx project from cubeide. (This one works/simulate without an issue)
  2. Push the project to git.
  3. Clone the project to another location
  4. Open touchgfx and try to simulate.
I am getting this error when i try to simulate.
Run Simulator
  Generate
    Done
  Generate Assets
    make -f simulator/gcc/Makefile assets -j8
    generated/simulator/gcc/Makefile:215: recipe for target 'images' failed
    process_begin: CreateProcess(NULL, ../Middlewares/ST/touchgfx/framework/tools/imageconvert/build/win/imageconvert.out -r assets/images -w generated/images, ...) failed.
    make (e=2): The system cannot find the file specified.
    make[1]: *** [images] Error 2
    simulator/gcc/Makefile:32: recipe for target 'assets' failed
    make: *** [assets] Error 2
    Failed
  Failed
This is my git ignore.
/Debug/
/Release/
/TouchGFX/build/
/Middlewares/ST/touchgfx/lib/
/TouchGFX/generated/
/TouchGFX/simulator/msvs/.vs/
/.settings/
*.vcxproj.filters
*.VC.db
*.VC.opendb
CKauf
Jul 27, 2020 7:13 AM UTC
If I remember correctly, I had to un-ignore the imageconvert.out and fontconvert.out files inside the /Middlewares/ST/touchgfx/framework/tools/...convert/build directory.
# but do NOT ignore these files!
!imageconvert.out
!fontconvert.out
But my .gitignore is purely based on filetypes, so your mileage may vary.
Senior III
Dec 22, 2025 4:26 PM UTC
I'm having the same issue.
Shouldn't imageconvert.out and fontconvert.out generated by TouchGFX when generating the code?
@Osman SOYKURT
vishraadh
Jul 26, 2023 10:31 AM UTC
Hello @Kasun Dinesh
I have run into a similar issue and was wondering if you were able to fix this?
Feb 7, 2024 9:54 AM UTC
I know it has been a while since you raised this query. I encountered a similar issue and renaming my project to a smaller name worked for me.
I hope this solution helps someone else facing a similar problem.
Osman SOYKURT
Feb 7, 2024 10:46 AM UTC
Hello @MVagh.2 ,
Thank you very much for sharing your solution. I'll close this thread since it has been open for 4 years now. If anyone is facing this issue again, please start a new thread in the community, we'll see what we can do.
