ET.2
Mar 1, 2023 6:15 AM UTC
TouchGFX showing undefined reference to global variable
I am new to TouchGFX, I ran into a problem that using TouchGFX 4.21.1 on STM32H743Eval 2 , I add a global variable (e.g. counter) within "USER CODE BEGIN 0", , in StartDefaultTask, add counter++ in the main.c file, follow MVP design procedure, just want to dispaly counter value in TextTArea widget, CubeIDE code compiling is ok, but when click "run simulator", it appers "C:\TouchGFXProjects\STM32H743\TouchGFX/gui/src/model/Model.cpp:13: undefined reference to `counter'
I am also using 4.18.0 of touchgfx, both have same symptom, is there any setting I missed, please help, thanks in advance.
SKacp.1
SKacp.1Best answer
Mar 1, 2023 7:38 AM UTC
Hi
You can't use with simulator global variables from Your main.c.
If You won't check Your program with global variables in simulator You must use #ifndef SIMULATOR in Model.cpp
#ifndef SIMULATOR
extern "C"
	#include "main.h"
#endif
SKacp.1
Mar 1, 2023 6:58 AM UTC
Please use extern "C" and include Your "h" file with global variables in Model.cpp.
extern "C"
	#include "main.h"
ET.2
ET.2Author
Mar 1, 2023 7:15 AM UTC
Thanks for the reply, I add exter C as you suggest as below:
#include <gui/model/Model.hpp>
#include <gui/model/ModelListener.hpp>
extern "C"
#include "main.h"
extern int counter;
Model::Model() : modelListener(0)
void Model::tick()
modelListener->indxpresenter(counter);
but, ​it shows no main.h as following...
Compile
    make -f simulator/gcc/Makefile -j8
    Reading ./application.config
    Compiling gui/src/model/Model.cpp
    gui/src/model/Model.cpp:6:11: fatal error: main.h: No such file or directory
     #include "main.h"
    compilation terminated.
SKacp.1
SKacp.1Best answer
Hi
#ifndef SIMULATOR
extern "C"
	#include "main.h"
#endif
