APate.18
Oct 19, 2023 12:09 PM UTC
TouchGFX : Scrolllist
Container Has 3 Widget (Box , 2 Button )
Container is used in scroll list , I have selectedHandler for Index but how can we get Which widget is selected form this itemIndex .
Oct 24, 2023 8:24 AM UTC
Hello @APate.18 ,
ScrollList is used for similar items, but you are planning to use different items. In this case, it's better to use Scrolable Container instead, and then using interactions for each button to implement your desired functionalities.
You can read more about Scrolable Containers here:
https://support.touchgfx.com/docs/development/ui-development/ui-components/containers/scrollable-container
Don't hesitate to ask more questions
Mohammad MORADIST Software Developer | TouchGFX
APate.18
APate.18Author
Oct 25, 2023 5:26 AM UTC
Hey MORADI ,
Thanks for reply
Actully i am using list of elements as i have attached one image
I have Few requirement for this
1) This List should be scrollable and list of item should decided on runtime
2) There are 3 different widgets in one container
     i) Up arrow as a button 01
     ii) Down Arrow as a button 02
     iii) Box
all 3 are tapeable
3) while we tapped on widget we require
          i) Index of tapped item
          ii) which widget is tapped
for saving their state
please let me know any solution for this i have tried scroll list but it wont work for saving state of tapped item differently because we get one index from handler
its little bit urgent
Graduate II
Oct 25, 2023 5:11 PM UTC
Hello
You can use callbacks to trigger parent (view) when some of those three widgets is pressed. Here is simple example, modified from some old example. I was lazy and use flex button as text box. You run it on simulator, it is made in version 4.21.4 but seems to work also on later versions.
Hopefully you get the idea out of it.
Br JTP
