DEtie.2
July 7, 2021
TouchGFX Scroll-wheel issues
I'm trying to implement the scroll wheel, I've followed this example: https://support.touchgfx.com/docs/development/ui-development/ui-components/containers/scroll-wheel
The scrollwheel is configured with the Selected Template Style.
There is my override methods:
void CurrentCalView::RangeListUpdateItem(NavigateItem& item, int16_t itemIndex)
	Unicode::UnicodeChar t[10];
	Unicode::snprintfFloat(t, 10, "%.1f A", ranges[itemIndex]);
	item.setText(t);
void CurrentCalView::RangeListUpdateCenterItem(NavigateItemSelected& item, int16_t itemIndex)
	item.setText(t);
While the non-selected item displays properly, the selecteditem does not. It seems to display random items.
The menu is moved using RangeList.animateToItem
Digging a bit in the code, I found out that the GFX generates the code as follow (10 items is configured in the GFX):
touchgfx::ScrollWheelWithSelectionStyle RangeList;
 touchgfx::DrawableListItems<NavigateItem, 8> RangeListListItems;
 touchgfx::DrawableListItems<NavigateItemSelected, 2> RangeListSelectedListItems;
Is that issue is caused by the fact that selected item is set to 2? Shouldn't be 10? Why 2?
