Danielj
TouchGFX: Pop-up container doesn't block a buttons under it.
  • October 19, 2020
  • 4 replies
  • 1256 views
I made a warning pop up container which "cover" all screen, but buttons under it remains active. Is there any solution for that kind of problem? (I know I can add a dummy button under the container but I think about other, more straight options).
Regards.
Romain DIELEMAN
Within your code you could make sure that buttons are set as non visible when you have the warning pop up.
NameOfButton.setVisible(false); //or true when done
When non visible, buttons cannot be interacted with.
/Romain
Martin KJELDSEN
Principal III
October 23, 2020
Another way is to make your popup toucheable. If it's on top, then it will "absorb" all the clickEvents and anything below it cannot be touched.
/Martin
Danielj
DanieljAuthor
Thanks for fast responses.
Regards.
Martin KJELDSEN
Principal III
October 23, 2020
No sweat. Report back with your progress :)
/Martin
