Professional
Feb 22, 2019 6:59 AM UTC
touchGFX : not link compatible with the new (C++14) library for IAR
i use IAR in time limited demo version IAR workbench 8.33.3.20228 (shared compnent 8.2.3.5849)
I can't link the generated code from thouchGFX designer : i have the following errors :
Error[Li060]: module "AbstractPainter.o(touchgfx_core.a)" contains C++ code built for use with the (E)C++98 library. This code is not link compatible with the new (C++14) library.
Error[Li060]: module "Screen.o(touchgfx_core.a)" contains C++ code built for use with the (E)C++98 library. This code is not link compatible with the new (C++14) library.
Have you any idea of how to solve this ?
best regards
Professional
Feb 22, 2019 7:06 AM UTC
it seems that we have to take project under \NSTD2F746_Disco\target\IAR8.xand not \NSTD2F746_Disco\target\IAR.
Is it correct ?
