May 15, 2025 10:18 AM UTC
TouchGFX no internet connection
I still have the same issues since a few releases of TouchGFX also in the new release that i can not download the boards or any demo or so out of the software. What is the reason to this? I tried a lot of things but it wont work. So is there any solution to that issue? Thanks a lot for the Help.
Senior III
May 15, 2025 11:20 AM UTC
Add TouchGFX to the allowed list of your firewall/antivirus. If you're behind a corporate proxy, TouchGFX might not automatically detect it.
May 15, 2025 11:47 AM UTC
I have checked it but the firewall is not blocking it. And I do not use a proxy. But even if I choos no proxy at the setting the connection fails.
GaetanGodart
May 15, 2025 11:36 AM UTC
Hello @DominikBiscette ,
Do you have a red triangle at the top of your TouchGFX Designer?
You can fix that in "File" => "Settings" => "Set proxy":
Regards,
Gaetan GodartSoftware engineer at ST (TouchGFX)
