ALin
Nov 28, 2019 6:58 AM UTC
TouchGFX isn't generating a Keil Project
I recently have a problem using TouchGFX. After editing UI in TouchGFX, I generated code. But there is only Visual Studio project and no other IDE's project code(Keil or IAR). In target folder, there are just some files. How can I solve it
Martin KJELDSEN
Principal III
Nov 28, 2019 8:00 AM UTC
I need more information.
How did you create the project? What's your target? Etc!
If you create a "simulator" project, then you won't get any target compiler projects.
/Martin
