Jul 15, 2025 6:16 PM UTC
TouchGFX image convertor
We are using TouchGFX for LCD UI design.  It seems that the generated c files for image have reverse-ordered 16-bit data.  We have to revert the image at run-time.  Is there a way to revert the 16-bit order during image converting?
    Aug 20, 2025 12:55 PM UTC
    Hello Izlin,
    By reverse, you mean little/big endian ? If so, no there's no way to switch edianess.
    What is your use case ?
    BR,
    Louis B.
    Louis BOUDOST Software Engineer | TouchGFX
