SLiau
Mar 22, 2019 7:55 AM UTC
TouchGFX idling on a screen sometime is showing random lines
Hi, I'm Hill-Rom employee and working on UI software. On the device LCD screen if leaving a screen idle for a while, sometime will observe some random lines showing on screen.
Not every time idling on the same screen can reproduce the issue but when the problem comes it's always the same lines appearing on the screen. Can you help me find out the problem?​
Martin KJELDSEN
Martin KJELDSENBest answer
Principal III
Apr 3, 2019 8:50 AM UTC
Could be some sort of memory contention. You have the LTDC and DMA2D accessing SDRAM at the same time, and maybe something else too?
Are you still having this problem?
/Martin
Martin KJELDSEN
Principal III
Mar 22, 2019 12:53 PM UTC
Hi @SLiau​,
That sounds a bit tricky to debug. Can you show me a screenshot to begin with?
Thanks.
Martin KJELDSEN
Principal III
/Martin
SLiau
SLiauAuthor
Apr 30, 2019 6:11 AM UTC
Hi Martin,
Sorry for the very late reply. Big thanks for pointing out LTDC and DMA2D accessing SDRAM at the same time.
I’ve tried adding Interrupt Critical region to both interrupt handler (LTDC & DMA2D), ISR_CRITICAL_ENTER() and the random line issue no longer happen. I believe it helps to prevent LTDC & DMA2D accessing SDRAM simultaneously.
In this case, I did no lockDMAToFrontPorch and maintain good performance.
Thanks again.
Shu Hwa
