touchGFX guiTask It runs for a few minutes and stops.
hi all.
I use touchGFX with FreeRTOS.
My other Task is working fine. However, A few minutes after the system starts, the touchGFX task is blocked and will not run. This phenomenon occurs more quickly when the 16-bit control is performed than when the external RAM data line is 32-bit.
I'm not sure what I'm going to review. What should I check?
