Touchgfx Graph widget
I know that there are a lot of questions and request for graph widget, yet there is no dependeble answer has been provided. It seems that there was a graph widget in previous versions, unfortunately not available now. I wonder if there is any ready to use graph widget that I can add to my project. The most needed feature is the ability to be updated and be able to shift the graph to the left side. The rival product (STEMWIN) has this feature.
Alexandre RENOUX
Alexandre RENOUXBest answer
October 4, 2020
The new version 4.15 will be released by the end of this week (8th of October normally)
Please let us know if you have successfully installed the new version end of this week.
Sorry for the wait,
Alexandre
Alexandre RENOUX
August 17, 2020
A graph widget is currently being made which will be available in the Designer. This will be released with the next version of TouchGFX (4.15) scheduled normally for September.
/Alexandre
August 18, 2020
We are hopeful that it will be released earlier.
Romain DIELEMAN
Meanwhile the graph widget comes out, have you had a look at the graphs in Demo 1 and Demo 2 (found in the UI examples on TouchGFX Designer). The code is available so you can copy it and adapt it to your needs for now.
/Romain
APaul.2
October 9, 2020
There is Dynamic Graph widget available in Miscellaneous
APaul.2
October 12, 2020
First of All, the STM32 cube MX has to be updated. And then the new version will be available in MX
