Krautermann
Senior
May 17, 2023 12:56 PM UTC
Touchgfx files with C only!
Every project generated from TouchGFX Designer is based on C++ (file .cpp). Is there a possibility to have project generated from TouchGFX Designer based on C only (file .c)?
Also are there any examples from TouchGFX Designer where the codes are in C?
Peter BENSCH
Peter BENSCHBest answer
May 17, 2023 3:22 PM UTC
TouchGFX is completely based on C++, so it is not possible to generate pure C code.
/Peter
Peter BENSCH
/Peter
