PZamb.2
Oct 18, 2023 7:46 AM UTC
touchgfx fade-in fade-out single button
Hi
I would like fade-in and fade-out of widget text, using a single button ,is possible?
How I can do?
Thank
PZamb.2
PZamb.2Best answer
Oct 18, 2023 2:40 PM UTC
Hallo
Thank for your answer, i create fade botton on/off with option "Add C Code" and implemented a virtual function in screenView:
void screenView::function1()
if (ROI_Txt.getAlpha()>200) {
ROI_Txt.clearFadeAnimationEndedAction();
ROI_Txt.setFadeAnimationDelay(6);
ROI_Txt.startFadeAnimation(0, 120, touchgfx::EasingEquations::linearEaseIn);
else
ROI_Txt.startFadeAnimation(255, 120, touchgfx::EasingEquations::linearEaseOut);
I'll Try your suggest.
Thank
Osman SOYKURT
Oct 18, 2023 2:31 PM UTC
Hello @PZamb.2 ,
You can easily do it with a toggle button for example, but you can also do it with a regular button based on the pressed state (with the getPressedState() function) of it.
Do you want support to make the fade animation or is it the button part that you need help on?
PZamb.2
PZamb.2AuthorBest answer
Hallo
else
Thank
