Aug 27, 2025 1:25 PM UTC
Touchgfx Double Frame Buffer Custom SPI Interface Example
- 9 replies
- 1072 views
I drived lcd by using partial frame buffer. Now, I am trying to update it with double buffer strategy. The LCD has TE pin that helps checking Vsync.
I could not find a clear example for double buffering method. I don't need FMC since internal ram is enough for driving.
Do you have any example or steps that I need to follow for those specs:
Touchgfx with double buffer + FreeRTOS (CMSIS V2) + SPI LCD (With TE pin)
Touchgfx Version : 4.25.0
CubeIde Version : 1.17.0
MCU : H7 series
Best regards,
Faruk
