Ajoub.1
TouchGFX designer: the remote server returned an error: (403) Forbidden
TouchGFX Designer doesn't show me any online application or template (just the Simulation with the black UI template).
I'm using version 4.16.0 and it shows me the following error :
Package server at HTTP://packages.touchgfx.com/V2/packages.json.zip can not be reached No online packages can be found.
You can continue working, but only already installed packages are available.
the remote server returned an error: (403) Forbidden.
I try also the newest version 4.17.0 and it shows me, "the application is not connected to the internet"
Ajoub.1
Ajoub.1Best answer
hello, thank you for your answer, I fix the problem, I didn't know how, I just open the software and it work
Hello @Ajoub.1​ ,
Can yo please try the temporary fix shared in this post ?
Imen
Ajoub.1
Ajoub.1AuthorBest answer
