MPath.4
Mar 31, 2023 7:00 AM UTC
Touchgfx Designer is not opening in the computer.
 last time also this problem was occured so I installed it again after that it run for some days now again the problem has occured.
 When I open Touchgfx one msg come
Sorry - something unexpected has happened which caused an error to occur in the Designer.
For more information, see the log file located at: C:\Users\Kaushal\AppData\Roaming\TouchGFX-4.21.3\TouchGFXDesigner.log
Please someone help to give the solution of it.
Yoann KLEIN
Yoann KLEINBest answer
May 8, 2023 1:43 PM UTC
Hello @MPath.4​,
You can manually install the generator, by following the steps described at the bottom of this post.
/Yoann
Yoann KLEINST Software Developer | TouchGFX
Yoann KLEIN
Mar 31, 2023 8:08 AM UTC
Hello @MPath.4​,
When does that happen? Right after launching TouchGFXDesigner? Or after doing something specific while designing your application?
Could you also share the log file you referred to?
Thank you.
/Yoann
MPath.4
MPath.4Author
Mar 31, 2023 8:43 AM UTC
Yoann KLEIN
Apr 3, 2023 7:39 AM UTC
Could you share the whole .log file ? Would be better for debugging.
Thanks,
/Yoann
MPath.4
MPath.4Author
Apr 5, 2023 5:50 AM UTC
MPath.4
MPath.4Author
Mar 31, 2023 8:45 AM UTC
MPath.4
MPath.4Author
Apr 1, 2023 4:18 AM UTC
Last day I made one application and closed it after that and the next day I opened but it had given the error.
MPath.4
MPath.4Author
Apr 11, 2023 5:39 AM UTC
I download the version 4.20.0 of Touchgfx designer and it's working then why the version 4.21.3 is not working.
Yoann KLEIN
Apr 11, 2023 3:14 PM UTC
I discussed your issue with my colleagues and we think that it could come from something written under a wrong format inside the .touchgfx file of your project.
Could you please share it here so we can check that ?
/Yoann
MPath.4
MPath.4Author
Apr 12, 2023 8:21 AM UTC
Yoann KLEIN
Apr 13, 2023 6:57 AM UTC
This file looks empty or erroneous, did you modify it before sharing it ?
/Yoann
MPath.4
MPath.4Author
Apr 14, 2023 4:09 AM UTC
No I didn't I send it to you once again
MPath.4
MPath.4Author
Apr 14, 2023 4:10 AM UTC
