Senior III
Mar 7, 2025 2:39 PM UTC
TouchGFX Designer 4.25 won't load image preview of projects
I've updated from TouchGFX Designer 4.24 to 4.25 and I've noticed that the example projects won't load the previews. Same machine, same internet connection
4.25
4.24
    nico23Best answer
    Senior III
    Mar 10, 2025 10:57 AM UTC
    I've opened and close various time and it showed it again
    GaetanGodart
    Mar 10, 2025 10:49 AM UTC
    Hello @nico23 ,
    Can you check your proxy settings :
    And make sure you do not have a pink triangle on the top left of your screen.
    Regards,
    Gaetan GodartSoftware engineer at ST (TouchGFX)
    nico23AuthorBest answer
    Senior III
    GaetanGodart
    Mar 10, 2025 11:42 AM UTC
    So closing and re-opening TouchGFX Designer solved the issue?
    Regards,
    nico23Author
    Senior III
    Mar 10, 2025 11:43 AM UTC
    yup, did that 2/3 times and preview re-appeared (internet was working properly, no proxy was set and no triangle appeared)
