awiernie
Touchgfx designer 4.22 crashes
After upgrading from TouchGFX 4.21.3 to Touchfx 4.22.0 the project was converted. If I open the touchgfx project the touchgfx designer crashes:
Application: TouchGFXDesigner-4.22.0.exe
CoreCLR Version: 7.0.122.56804
.NET Version: 7.0.1
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IndexOutOfRangeException: Index was outside the bounds of the array.
at TouchGFXDesigner.Communications.NewsManagerViewModel.SwitchCurrentCard(Object state)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
--- End of stack trace from previous location ---
at System.Threading.TimerQueueTimer.Fire(Boolean isThreadPool)
at System.Threading.TimerQueue.FireNextTimers()
at System.Threading.ThreadPoolWorkQueue.Dispatch()
at System.Threading.PortableThreadPool.WorkerThread.WorkerThreadStart()
    Osman SOYKURT
    Hello @awiernie
    Could you share with us your 4.21.3 project? We would need it to investigate what's happening here.
    (You can share it to me in PM if you prefer).
    awiernie
    awiernieAuthor
    I have sent you a download link for the whole STM32CubeIDE project.
    awiernie
    awiernieAuthor
    It occures a few seconds after loading (without any user interaction) or after a few minutes with the same windows event log.
