KM L.1
Touchgfx color inversion
We are working on the TouchGFX with STM32H7 controller , able to display the images but colors are getting inverted on the LCD. TouchGFX and LTDC configuration looks fine. So what may be the issue.
For Black <--> White
Blue <--> Yellow
Red <--> Blue
Green <--> Magenta
Thank You
Romain DIELEMAN
How did you configure your display ? Before enabling TouchGFX were the colors fine ? You can have a look at the board bring up articles in the online documentation to see how to check and test the display colors.
I believe you are working on a custom board, but you can have a look athe how the ST dev kits are configured by created a project from TouchGFX designer and selecting an application template for a ST kit using an H7 mcus.
/Romain
KM L.1
KM L.1Author
Before enabling the TouchGFX we have not looked into the colors..
Yes we are working on a custom board.
Please look into my touchgfx configuration i have attached.
Romain DIELEMAN
cant really help you without a datasheet. But Like I said, you should disable TouchGFX for now and try to test the display by itself to check the colors.
/Romain
