Martin KJELDSEN
Principal III
Oct 30, 2020 10:02 AM UTC
(Copied from my reply to the other post)
Hi, this is a problem with msys.dll - You most likely have multiple ones on your path (TouchGFX Envs being one of them).
It's a common problem out there in the real world and the solution seems to be to "rebase" the dll. Can you try searching for that solution and get back to me?
