Jul 30, 2025 9:42 AM UTC
TouchGFX Build Error
Hello, I am working with TouchGFX Designer version 4.25.0 and STM32Cube IDE 1.13.2 .
Since today my build process does not work anymore and I get errors that some of the .hpp files are not existent. error notificationserror notifications
I did double check the "missing" files but they are existent.
Has anybody already had this problem and maybe can suggest a solution?
Thank you very much.
MM..1
Jul 30, 2025 10:30 AM UTC
Exactly (absurd) normal, after ioc edit and generate code one step is required open tgfx project and too regenerate...
Alx237Author
Jul 30, 2025 11:50 AM UTC
Hi MM..1
Thanks for your quick response!
I tried your solution but still get the same errors unfortunately.
MM..1
Jul 30, 2025 12:00 PM UTC
Then maybe your cproject file is corrupt or project require refresh... You dont get info what you do...
Christian N
Aug 5, 2025 6:24 PM UTC
This post has been escalated to the ST Online Support Team for additional assistance. We'll contact you directly.
Regards,
Christian
