Jul 29, 2024 11:38 AM UTC
TouchGFX 4.24 and textfield in container
HI, could you come up with an example of how to access a textfield from a custom container in the Main screen?
Thanks in advance.
    tdecker2
    tdecker2Best answer
    Jul 29, 2024 2:00 PM UTC
    If you have 5 instances of your CustomContainer on your View, you can give every instance a different text:
    myContainer1.getTextArea.setTypedText(touchgfx::TypedText(T_TEXT1));
    myContainer2.getTextArea.setTypedText(touchgfx::TypedText(T_TEXT2));
    myContainer3.getTextArea.setTypedText(touchgfx::TypedText(T_TEXT3));
    myContainer4.getTextArea.setTypedText(touchgfx::TypedText(T_TEXT4));
    myContainer5.getTextArea.setTypedText(touchgfx::TypedText(T_TEXT5));
    tdecker2
    Jul 29, 2024 12:27 PM UTC
    You have to add a public method to your CustomContainer-class, for example
    void setText(Unicode::Unichar * text);
    And copy the text to your textfield wildcard array. Then you can call this method from your Main screen view class.
    Another way could be exposing the TextArea object to the outside world by adding a method like this:
    TextArea & getTextArea() { return myTextArea;}
    amigafanAuthor
    Jul 29, 2024 1:52 PM UTC
    HI, thanks for the quick replay, but a have 5 identical containers in Mainscreen and then the textfields will have the same ID, and I want to access them individually.
    tdecker2
    tdecker2Best answer
