Aug 15, 2023 5:46 AM UTC
TouchGFX 4.22 Run simulator when done compiler simulator.exe will close automatically
Like topic i can compiler demo code successfully and "run" simulator.exe, but result console will closed immediately, i only can use virtual studio 2019 open the "simulator.exe" and press debug then i can see the result, any good suggestion that i can do?
i already tried reinstall TouchGFX and VS2019, Or use admin excute TouchGFX, but it useless.
Sep 14, 2023 10:28 AM UTC
Hello @Mercy ,
Are you trying to run a demo which is exported from the designer or is it your custom project? If it's from designer, could you specify which demo you are trying to have the simulation?
Mohammad MORADIST Software Developer | TouchGFX
