FGREM.9
Apr 17, 2019 11:12 AM UTC
Touch GFX Errors while launching simulator and generating code.
Hy everybody,
I'm new on TouchGFX and after installing it, I opened a sample program and when I want to launch the simulator or generate the code, I get error messages.
Did I need to make some configuration to get it work?
Thanks in advance for reply,
Regards.
cameronf
Apr 17, 2019 7:14 PM UTC
Can you post the errors? People will likely to be able resolve issues related to a specific error.
Martin KJELDSEN
Principal III
May 16, 2019 12:17 PM UTC
Hi @FGREM.9​,
Did you manage to solve this? If it says "unable to generate code" try removing the "PostGenerateCommand" command in the .touchgfx file or replace it with something like "echo test" - Designer will complain if empty (but not fail).
