IB.1
Touch GFX dynamic Graph widget crash the application
Hello Touch GFX Guys.
Hardware: STM32H7B3I development board
Software: Touch GFX designer 4.16
STM Cube IDE 1.5.0
We are trying to experiment with "dynamic graph" widget and experiencing some problems .
After adding widget on the screen follow code is generated
 dataGraph1.setScale(1);
 dataGraph1.setPosition(10, 10, 380, 180);
 dataGraph1.setGraphAreaMargin(0, 0, 0, 0);
 dataGraph1.setGraphAreaPadding(0, 0, 0, 0);
 dataGraph1.setGraphRangeY(0, 100);
 dataGraph1Line1.setScale(1);
 dataGraph1Line1Painter.setColor(touchgfx::Color::getColorFrom24BitRGB(20, 151, 197));
 dataGraph1Line1.setPainter(dataGraph1Line1Painter);
 dataGraph1Line1.setLineWidth(2);
 dataGraph1.addGraphElement(dataGraph1Line1);
 dataGraph1.addDataPoint(6.40222585735995f);
 dataGraph1.addDataPoint(15.6299816028386f);
 dataGraph1.addDataPoint(9.83211034085783f);
 dataGraph1.addDataPoint(10.0465691581937f);
Once we run the application code is crushing. if we comment
and all follow lines:
application is running but obviously no graph :)
We do not have any functions in the code to update graph yet...
We tried to set in CANVAS BUFFER "Overwrite default buffer size " to 7200 bytes
but no luck.
Please advise if anything else we can do to overcome this problem, or any other information we can provide.
Thank you for all your help and support
Regards,
i
IB.1
IB.1Author
Hi Alexandre,
Did you have a chance to look at the issue.
please advise at your earliest convenience.
Thank you,
I
Alexandre RENOUX
January 28, 2021
Hello @IB.1​ ,
Yes I've looked at the issue and I personally don't find anything wrong with your loader file. Unfortunately, I haven't found the root of your problem yet. I'm in discussion with the dev team but this takes more time than expected.
Sorry for the inconvenience.
/Alexandre
IB.1
IB.1Author
Hi Alexandre,
Thank you for your replay. please keep us posted
Regards,
I
IB.1
IB.1Author
Hi Alexandre,
Can you please advise, what is status of this request?
Thank you,
I
IB.1
IB.1Author
Hi Alexandre,
Thank you,
I
IB.1
IB.1Author
Hi Alexandre,
Thank you,
I
