S.Mirza
Touch event problem
Hi. I generate a touchgfx project that toggle an led by pressing a button. the problem is trigger action by clicking button is randomly happen. the problem comes from that the touch function gets some touch sample and they slightly different .How do I fix this Issue?
S.Mirza
S.MirzaAuthor
Hello. You are right Alexandre RENOUX(ST Employee). I found the problem. When I touch the touch screen, the function return the true coordinate but at the moment I release the touch, the last coordinate was unvalid (I mean the last coordinate that the function returned is outside of the range. ) so I filtered the unvalide coordinate and the problem solved.
thanks to everyone.
