Aug 19, 2025 5:53 AM UTC
The text area cannot display correctly when the user inputs a character array.
Hello every,
I created some text areas to display the file name, which comes from a character array provided by the user's input.
Below are the configuration settings for each text area.
1.text area
2.Texts->Typographies
3.code
3.1.text area define in class
 touchgfx::TextAreaWithOneWildcard data06_text;
 touchgfx::TextAreaWithOneWildcard data05_text;
 touchgfx::TextAreaWithOneWildcard data04_text;
 touchgfx::TextAreaWithOneWildcard data03_text;
 touchgfx::TextAreaWithOneWildcard data02_text;
 touchgfx::TextAreaWithOneWildcard data01_text;
 static const uint16_t DATA06_TEXT_SIZE = 32;
 touchgfx::Unicode::UnicodeChar data06_textBuffer[DATA06_TEXT_SIZE];
 static const uint16_t DATA05_TEXT_SIZE = 32;
 touchgfx::Unicode::UnicodeChar data05_textBuffer[DATA05_TEXT_SIZE];
 static const uint16_t DATA04_TEXT_SIZE = 32;
 touchgfx::Unicode::UnicodeChar data04_textBuffer[DATA04_TEXT_SIZE];
 static const uint16_t DATA03_TEXT_SIZE = 32;
 touchgfx::Unicode::UnicodeChar data03_textBuffer[DATA03_TEXT_SIZE];
 static const uint16_t DATA02_TEXT_SIZE = 32;
 touchgfx::Unicode::UnicodeChar data02_textBuffer[DATA02_TEXT_SIZE];
 static const uint16_t DATA01_TEXT_SIZE = 32;
 touchgfx::Unicode::UnicodeChar data01_textBuffer[DATA01_TEXT_SIZE];
3.2.display the file name
void selectFileScreenView::SendOpenFileTitle(const uint16_t index, const char *title)
	//Debug_Printf("title:%s", title);
	switch(index){
	case 0:
		Unicode::snprintf(data01_textBuffer, DATA01_TEXT_SIZE, "%s", title);
		data01_text.invalidate();
		break;
	case 1:
		Unicode::snprintf(data02_textBuffer, DATA02_TEXT_SIZE, "%s", title);
		data02_text.invalidate();
		break;
	case 2:
		Unicode::snprintf(data03_textBuffer, DATA03_TEXT_SIZE, "%s", title);
		data03_text.invalidate();
		break;
	case 3:
		Unicode::snprintf(data04_textBuffer, DATA04_TEXT_SIZE, "%s", title);
		data04_text.invalidate();
		break;
	case 4:
		Unicode::snprintf(data05_textBuffer, DATA05_TEXT_SIZE, "%s", title);
		data05_text.invalidate();
		break;
	case 5:
		Unicode::snprintf(data06_textBuffer, DATA06_TEXT_SIZE, "%s", title);
		data06_text.invalidate();
		break;
	default:
		break;
4.result
I’m sure that the const char *title is correct, but all the text areas display "???????????". Please help me fix this. Thanks in advance
JTP1Best answer
Graduate II
Aug 19, 2025 7:58 AM UTC
Hello Leon Su
I think Unicode::snprintf expects that the printed string ('title' in your case) should be at Unicode format (16 bit).
Try to use unicode::fromUTF8 instead.
Something like
Unicode::fromUTF8(title,data01_texyBuffer,DATA01_TEXT_SIZE);
 Hope this helps.
br JTP
JTP1Best answer
Graduate II
Hello Leon Su
Something like
 Hope this helps.
br JTP
LeonSuAuthor
Aug 20, 2025 12:38 AM UTC
thaks @JTP1
It works perfectly. Thank you again!
